[GRASS-dev] Re: [GRASS GIS] #306: v.in.ogr GUI is missing --o and --v
GRASS GIS trac at osgeo.org
Fri Sep 12 05:05:15 EDT 2008
  Reporter:  msieczka     |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  major        |   Milestone:  6.4.0
 Component:  wxGUI        |     Version:  svn-develbranch6
Resolution:               |    Keywords:
  Platform:  All          |         Cpu:  All
Comment (by mlennert):
 Replying to [comment:16 neteler]:
 > Replying to [comment:14 hamish]:
 > > Glynn:
 > > > The behaviour is dictated by the underlying widget provided by
 > > > the toolkit
 > > right, but we can make tabs at will, and we can call one "...".
 > To have a pseudo tab containing a title "..." would be perfect.
 > If that's possible, the problem will be psychologically solved.
 Just to add my own 2 cents. I think the major problem is what you stated
 earlier:
 "If you only see complete tabs and then space on the right then you don't
 get there idea that there could be more tabs hidden."
 IMHO, it is this _space_ which is the major cause of confusion. Can this
 space be controlled ?
 Moritz
 > Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/306#comment:17>
