[GRASS-dev] Re: r.external
Markus Neteler neteler at osgeo.org
Fri Sep 12 08:44:21 EDT 2008
On Mon, Sep 8, 2008 at 11:42 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> I have some troubles with the assignment of colors.
>> The map is a FP DTM map, and the d.rast output is
>> all white (while r.univar reports 815886 non-null cells).
>> I assume that this is to to the absence of (some) file
>> statistics (f_quant file?).
> The current version writes the f_quant file (although not correctly;
> it forgot to call G_quant_init() first; fixed in r33337).
Backported.
Now, after r.external of a
Band 1 Block=23522x1 Type=Float32, ColorInterp=Gray
map, the color table is gray (so, ok).
Then
r.colors pat_dtm_5m col=elevation
d.rast pat_dtm_5m
leads to a white map.
> It doesn't write a histogram; you can use "r.support -s ..." to create that.
I suppose that this is in GRASS 6:
r.support.stats pat_dtm_5m
Statistics for <pat_dtm_5m> updated
r.info -r pat_dtm_5m
WARNING: category support for [pat_dtm_5m] in mapset [PERMANENT] missing
min=nan
max=nan
Color table for <pat_dtm_5m> set to elevation
d.rast pat_dtm_5m
 100%
... still white.
> Does the map have the correct bounds?
You mean spatially? Yes (the original gray table works).
> Does it have a colour table (try d.legend)?
d.legend pat_dtm_5m
WARNING: Category file for <pat_dtm_5m> not available
Apparently not: all "nan".
> Can you provide any information at all about the imported map?
gdalinfo pat_DTM_2008_derived_5m_UTM_WGS84.tif -mm
Computed Min/Max=0.000,3758.871
  Overviews: 11761x9755, 5881x4878, 2941x2439, 1471x1220, 736x610,
368x305, 184x153
Could the GDAL histogram be used anyhow (r.support takes a while on
this 2GB file)?
I am on a 64bit Linux box.
thanks
Markus
