[GRASS-dev] Re: r.external
Fri Sep 12 20:42:37 EDT 2008
Markus Neteler wrote:
> > It doesn't write a histogram; you can use "r.support -s ..." to create that.
> I suppose that this is in GRASS 6:
> r.support.stats pat_dtm_5m
> Statistics for <pat_dtm_5m> updated
> r.info -r pat_dtm_5m
> WARNING: category support for [pat_dtm_5m] in mapset [PERMANENT] missing
> min=nan
> max=nan
Well, that's the problem. Does "r.external -r" help? Does r.in.gdal
import the map correctly?
