[GRASS-dev] getting vdigit to compile correctly on the Mac
William Kyngesburye woklist at kyngchaos.com
Sat Sep 13 13:20:16 EDT 2008
On Sep 13, 2008, at 10:54 AM, Michael Barton wrote:
> Here is a link to discussion that may help explain why vdigit is not
> compiling correctly on a Mac--especially with OX X 10.5 (Leopard)
> that comes with Python 2.5--and a couple of solutions to fixing it.
> http://mail.python.org/pipermail/pythonmac-sig/2008-January/
> 019628.html
I've suggested distutils before.  It just needs someone to write the
setup.py script.
Also, your problem may be a bit different - it may be configure that's
messing up.  Are the python flags in your platform.make pointing to
the system python or the python.org python?
Configure uses python-config to get the configuration of python
includes and libs.  If you just say "--with-python" (as I have in the
example in the GRASS OSX readme) configure will try to find it in your
PATH, and may be getting it wrong.
Try setting a path to python-config when configuring.  It should be /
usr/local/bin/python-config (symlinks installed by python.org
installer).  ie:
--with-python=/usr/local/bin/python-config
If configure is getting it right and it's still messing up the
linking, another possibility is that the python.org python doesn't
install lib symlinks in /usr/local/lib, so even though the library
path is specified it may get the system python from /usr/lib.  It's
not supposed to, but I've seen it happen with the system sqlite vs. my
sqlite framework (though not recently, maybe the new Xcode has fixed
this).
I could try it, but I don't want to mess up my MacBook by installing
(for real) the python.org python (I like the system python), though I
could try it on my Mini.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
