[GRASS-dev] Re: [GRASS GIS] #64: ps.map: patch to set customized scalebar units
GRASS GIS trac at osgeo.org
Mon Sep 15 03:47:32 EDT 2008
  Reporter:  alf          |       Owner:  hamish
      Type:  enhancement  |      Status:  closed
  Priority:  minor        |   Milestone:  6.4.0
 Component:  ps.map       |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  scalebar
  Platform:  All          |         Cpu:  All
Comment (by glynn):
 Replying to [comment:9 hamish]:
 > I don't know if it is possible to get the right-hand coordinate of a PS
 pseudo-text box when the text is left-justified. I do not wish to right-
 justify those labels.
 You can use the `stringwidth` operator to obtain the width of a string
 (the distance that the current point will move if you `show` the string).
 If the string is short, you can obtain the bounding box with a combination
 of the `charpath` and `pathbbox` operators (if the string is long,
 `charpath` may overflow the maximum path length).
Ticket URL: <http://trac.osgeo.org/grass/ticket/64#comment:10>
