[GRASS-dev] scale and offset in raster maps
andrea antonello andrea.antonello at gmail.com
Mon Sep 15 12:41:50 EDT 2008
>> I just wanted to know if the internal GRASS binary format has this
>> metadata inside. At that point I guess that the answer is no?
> Correct.
> For an integer map, you can store floating-point values in the
> category labels; some modules can use the values from the labels
> instead of the raw category value. You can also create a reclass map,
> but the values are restricted to integers.
Thanks, that is what I wanted to know.
Andrea
> Glynn Clements <glynn at gclements.plus.com>
