[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton michael.barton at asu.edu
Mon Sep 15 23:07:37 EDT 2008
Unfortunately, getting rid of the swig in /usr/local/bin didn't help.
No time now. I'll check more later.
Michael
On Sep 15, 2008, at 7:41 AM, William Kyngesburye wrote:
> With rare exceptions, anything in /usr/* is installed by Apple.  /
> usr/local/* should be where your old swig is.
> See where the first one is in your PATH with:
> type swig
> If it's still /usr/bin/swig, maybe you just need to reinstall Xcode.
> On Sep 15, 2008, at 9:32 AM, Michael Barton wrote:
>> I installed a swig binary a year or two back. I don't know if the
>> swig that I find in /usr/bin is from that or from the XCode
>> install. Any idea how to tell the difference?
>> If I delete /usr/bin/swig, do you think that stuff will still
>> compile (i.e., find the other swig)?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
