[GRASS-dev] Re: [GRASS GIS] #308: Compiler error while building python swig
GRASS GIS trac at osgeo.org
Tue Sep 16 02:16:45 EDT 2008
  Reporter:  cgsbob               |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect               |      Status:  new
  Priority:  major                |   Milestone:  6.4.0
 Component:  SWIG (all bindings)  |     Version:  svn-develbranch6
Resolution:                       |    Keywords:  python swig
  Platform:  Unspecified          |         Cpu:  Unspecified
Comment (by hamish):
 can {{{ extern CELL CELL_NODATA; }}} be removed from gis.h?
 AFAICT CELL_NODATA is not used or defined anywhere in the code.
 After removing CELL_NODATA python_grass6.pyc compiles ok upon running
 "python test.py" but then test.py gets stuck due to the new definition of
 G_gisinit():
   File "test.py", line 17, in ?
     g6lib.G_gisinit('')
 AttributeError: 'module' object has no attribute 'G_gisinit'
 Within a python shell "help(g6lib)" only shows G__gisinit() as a valid
 function name. Running g6lib.G__gisinit('','') in python exits with the
 mismatched version error.
 How to recreate these from gis.h in a way that SWIG will like?
 #define GIS_H_VERSION "$Revision: 33187 $"
 #define G_gisinit(pgm) G__gisinit(GIS_H_VERSION, (pgm))
 #define G_no_gisinit() G__no_gisinit(GIS_H_VERSION)
 if in test.py I replace G_gisinit() with G__gisinit():
 -g6lib.G_gisinit('')
 +g6lib.G__gisinit(g6lib.GIS_H_VERSION, '')
 Then it all works, but that's more to type.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/308#comment:18>
