[GRASS-dev] nviz compile errors on Mac OS X
Wed Sep 17 03:26:05 EDT 2008
Michael Barton wrote:
> >> wxNviz uses the GLCanvas, which requires PyOpenGL. Note that wxPython
> >> does not need PyOpenGL, but GLCanvas does.
> > Odd; I don't see an "import" statement for it in wx/glcanvas.py, nor
> > anything in the code which appears to use it.
> > Have you actually checked that it needs PyOpenGL?
> Well, it *used* to require PyOpenGL. I have not checked in the current
> version. Maybe it doesn't anymore, which is good. We may need to
> conditionalize PyOpenGL as a dependency if older versions of wxPython
> are used.
I uninstalled PyOpenGL, and the wx nviz tool still works (after
changing the grass6 references to grass7). So I've removed the checks
for OpenGL.GL and OpenGL.GLU.
