[GRASS-dev] Re: Problem when loading GRASS 6 raster with large integer values into R via r.out.bin
Roger Bivand Roger.Bivand at nhh.no
Tue Sep 23 13:52:01 EDT 2008
On Tue, 23 Sep 2008, Rainer M Krug wrote:
> On Tue, Sep 23, 2008 at 1:11 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>> OK - I finally got around to testing it.
>>> I installed spgrass6 as well as rgdal from source, as spgrass6 needed
>>> a newer version of rgdal then available in CRAN  (Error: package
>>> 'rgdal' 0.5-25 was found, but >= 0.5.26 is required by 'spgrass6').
>> Hi,
>> I had to modify rgdal to get writeRAST6() to use writeGDAL() - there was a
>> bug in otherwise unused code to setting the NODATA value in rgdal. Could you
>> try this out too? Should I try to trap the verbose messages?
> It is working for me, although when I am using useGDAL=FALSE, it is
> converted from integer to double (see below).
> In R:
>> x <- readRAST6("ros_2016.max",useGDAL=TRUE )
>> writeRAST6(x,"xuseGDALFALSE",useGDAL=FALSE )
> 100%
>> writeRAST6(x,"xuseGDALTRUE",useGDAL=TRUE )
> WARNING: Datum <unknown> not recognised by GRASS and no parameters found.
> Projection of input dataset and current location appear to match
> 100%
> r.in.gdal complete.
> In GRASS:
> GRASS 6.3.0 (grass):~/Documents/Projects/AlienSpread/R > r.info -r
> map=xuseGDALTRUE
> min=0
> max=36852
> [Raster MASK present]
> map=xuseGDALFALSE
> min=0.000000
> max=36852.000000
> Concerning trapping of the verbose messages, I think it would be a
> good idea to do the following:
> 1) add a parameter verbose=TRUE in readRAST6 and writeRAST6 to enable
> or disable it
I'll try to do this using the existing ignore.stderr= in system(), but it
may not stop everything.
> 2) if possible, raise an R error, if GRASS returns ERROR
If GRASS fails, the next actions on the R side should fail. I can look at
trying to capture the $? value returned by the R command in certain
places, but this involves a shell dependency that isn't convenient (as in
the native Windows version).
> This is one approach which I would be interested to use as well when
> calling GRASS commands from R.
> What is the
> ERROR 6:  SetColorTable() only supported for Byte or UInt16 bands in
> TIFF format.
> mean? Is it relevant for R?
Almost certainly not, it is a GDAL message, not an error as such, and
could be got round (I think) in r.out.gdal by only creating colour tables
for the GTiff driver if the conditions are met.
Roger
> Thanks
> Rainer
>> Best wishes,
>> Roger
>>> It is working, when using useGDAL=TRUE. See output below:
>>> In GRASS:
>>> map=ros_2016.max
>>> min=0
>>> max=36852
>>> In R:
>>>> x <- readRAST6("ros_2016.max",useGDAL=FALSE )
>>> Creating BIL support files...
>>> Header File =
>>> /home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/ecolmod/ros_2016.max.hdr
>>> World File =
>>> /home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/ecolmod/ros_2016.max.wld
>>> Exporting raster as integer values (bytes=2)
>>> Using the current region settings...
>>> north=6247000.000000
>>> south=6195000.000000
>>> east=270200.000000
>>> west=251000.000000
>>> r=520
>>> c=192
>>> 100%
>>>> range(x[[1]], na.rm=TRUE)
>>> [1] -31916  30755
>>> ERROR 6: SetColorTable() only supported for Byte or UInt16 bands in TIFF
>>> format.
>>> WARNING: Input raster map constains cells with NULL-value (no-data). The
>>>        value 999 was used to represent no-data values in the input
>>>        map.You can specify nodata value by nodata parameter.
>>> has GDAL driver GTiff
>>> and has 520 rows and 192 columns
>>> [1]     0 36852
>>> I would suggest that you proceed as suggested below.
>>> Thanks
>>> Rainer
>>> On Thu, Sep 18, 2008 at 11:01 PM, Roger Bivand <Roger.Bivand at nhh.no>
>>> wrote:
>>>> Roger Bivand <Roger.Bivand <at> nhh.no> writes:
>>>>> Markus Neteler <neteler <at> osgeo.org> writes:
>>>>>> On Wed, Sep 17, 2008 at 10:49 AM, Roger Bivand <Roger.Bivand <at>
>>>>>> means:
>>>>>> - the GDAL plugin is no option here since it does not respect current
>>>>>>  region settings
>>>>>> - r.out.gdal is good since it does the job (AFAIK). Written in C
>>>>> I can revisit this in relation to using r.out.gdal for GRASS >= 6.3
>>>>> instead of r.out.bin - in which case I can make r.out.gdal use 32
>>>>> bits for integers and 64 bits for float/doubles.
>>>> Committed on R-spatial sourceforge CVS, new flag useGDAL=FALSE for now
>>>> default, uses Int32 for CELL, so maybe could be tried to see if it works
>>>> better than r.out.bin.
>>>> If it does, I'll change writeRAST6() too, change the default to TRUE, and
>>>> release.
>>>> Roger
>>>>> Roger
>>>>>> Perhaps you mean r.out.gdal.sh?
>>>>>> Best
>>>>>> Markus
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Roger Bivand
>> Economic Geography Section, Department of Economics, Norwegian School of
>> Economics and Business Administration, Helleveien 30, N-5045 Bergen,
>> Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
>> e-mail: Roger.Bivand at nhh.no
Roger Bivand
