[GRASS-dev] i.rectify still chokes on @mapset
Moritz Lennert mlennert at club.worldonline.be
Wed Apr 15 13:44:39 EDT 2009
On 15/04/09 19:14, Markus Neteler wrote:
> On Wed, Apr 15, 2009 at 7:12 PM, Isaac Ullah <iullah at asu.edu> wrote:
>> To clarify,  the error is exactly this:
>> i.rectify group=central_hasa_square_60_69 at PERMANENT
>> input=central_hasa_square_60_69.1 at PERMANENT extension=rectify_test order=1
>> Input raster map <central_hasa_square_60_69.1 at PERMANENT> does not exist in
>> group <central_hasa_square_60_69 at PERMANENT>.
>>  Try:
>> central_hasa_square_60_69.alpha
>> Exit!
> three questions:
> - in which mapset are you currently? (g.gisenv)
> - does the group really exist? (g.list group)
> - please post the content of the group file
As the message says, the group file contains
central_hasa_square_60_69.1, but not
central_hasa_square_60_69.1 at PERMANENT. I would guess that the problem is
  in line 166 of imagery/i.rectify/main.c (ref to trunk) where you have
if (strcmp(ifile->answers[m], ref.file[n].name) == 0) {
without stripping the @mapset from the file name and so the comparison
with the files in the group fails.
Don't know how this is handled elsewhere, but should be fairly trivial
to correct, I would guess.
Moritz
