[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not work
Wed Apr 15 16:10:31 EDT 2009
Dylan Beaudette wrote:
> 3. Allow the user to specify what they would like NULL cells encoded as.
> Unless I am overlooking something, it would seem reasonable to export a CELL
> map to a signed integer format, and use some obvious negative value for NULL:
If you're exporting to a 32-bit (signed or unsigned) integer format,
the obvious choice for null is 0x80000000. That's what GRASS uses
internally, so it can never occur as a legitimate value (if a
computation ends up producing that value, it will get treated as a
null in all regards).
