[GRASS-dev] r.surf.fractal [was: v.buffer]
Paolo Cavallini cavallini at faunalia.it
Thu Apr 23 08:49:46 EDT 2009
Hamish ha scritto:
> in devbr6 and relbr6_4 I have added backwards compatibility aliases for
> the removed options. so all should be ok again.
Thanks for this.
Same thing happens for r.surf.fractal (option d=float has been changed
in option dimension=float). Could this also be fixed?
More generally: is there a list of changed options, so we can try and
fix them all?
Thanks.
Paolo Cavallini: http://www.faunalia.it/pc
