[GRASS-dev] Re: [GRASS GIS] #577: v.in.ogr: imported GPX file results in N=0, W=0
GRASS GIS trac at osgeo.org
Thu Apr 30 08:43:35 EDT 2009
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  6.4.0
 Component:  Vector  |     Version:  svn-develbranch6
Resolution:          |    Keywords:  v.in.ogr, gpx
  Platform:  Linux   |         Cpu:  x86-32
Comment (by hamish):
 a shapefile from ogr2ogr gives ok extent.
 (another bug is stopping me importing that, duplicate column names)
 $ ogrinfo -ro -al track_points.shp
 INFO: Open of `track_points.shp'
       using driver `ESRI Shapefile' successful.
 Layer name: track_points
 Geometry: Point
 Feature Count: 4532
 Extent: (170.168993, -46.055889) - (170.724047, -45.742630)
 Layer SRS WKT:
 GEOGCS["GCS_WGS_1984",
     DATUM["WGS_1984",
 aaaah, here is why:
 INFO: Open of `waypoints.shp'
 Layer name: waypoints
 Geometry: Point
 Feature Count: 0
 Extent: (0.000000, 0.000000) - (0.000000, 0.000000)
 Layer SRS WKT:
 the GPX import creates 5 layers:
 route_points
 routes
 track_points
 tracks
 waypoints
 but my GPX file only has tracks in it. so some of the other layers have no
 extent (and no features), but v.info picks up the 0.0 anyway.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/577#comment:2>
