[GRASS-dev] Re: [GRASS GIS] #715: OSGeo4W patch for DLLs
GRASS GIS trac at osgeo.org
Sun Aug 2 13:15:02 EDT 2009
  Reporter:  neteler       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  default       |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  All
Comment (by glynn):
 Replying to [ticket:715 neteler]:
 > Attached patch was submitted by Juergen Fischer, please review.
 Is there some reason that Shlib.make and Stlib.make can't use
 ARCH_CMD_OBJS, so that Makefiles can just override MOD_OBJS if they don't
 want the default?
 Failing that, Lib.make should use similar logic to Rules.make, i.e. only
 define the variables if they aren't already defined.
 Either way, Lib.make should not contain references to specific files
 (fmode.o and dllmain.o).
Ticket URL: <http://trac.osgeo.org/grass/ticket/715#comment:2>
