[GRASS-dev] Re: [GRASS GIS] #634: v.out.ogr error on Vista
Markus Metz markus.metz.giswork at googlemail.com
Sun Aug 2 14:18:27 EDT 2009
>   Reporter:  cnielsen         |       Owner:  grass-dev at lists.osgeo.org
>       Type:  defect           |      Status:  new
>   Priority:  major            |   Milestone:  6.4.0
>  Component:  Vector           |     Version:  svn-develbranch6
> Resolution:                   |    Keywords:  wingrass, v.out.ogr
>   Platform:  MSWindows Vista  |         Cpu:  x86-32
> Comment (by cnielsen):
>  Replying to [comment:6 mmetz]:
>  > The attached patch is for debugging only. It contains two minor
>  potential fixes plus some more debugging info.
>  The minor potential fixes seem to have worked. It works perfectly now.
>  Should I still post the debugging?
Forgot to mention, no, no more need to debug since it's working.
Assuming that you checked that the exported shapefile is ok, I submitted
changes to all branches and closed the ticket.
Thanks for your help,
Markus M
