[GRASS-dev] Some GRASS 7 doxygen links failing
Markus Neteler neteler at osgeo.org
Mon Aug 3 13:26:31 EDT 2009
we still have the problem that in
 http://download.osgeo.org/grass/grass7_progman/
two important links fail:
Interfaces
    * GRASS SWIG interface          <--- this
    * GRASS Python scripting library
GUI
    * wxGUI                                     <--- this
Why that? Because the master document is
lib/grasslibs.dox
and both failing directories are one hierarchical level above.
... while "GRASS Python scripting library" is inside the lib/
directory and hence the doxygen referencing system works.
Ideas:
- put the master document into the main directory (or create a new
  one?)
- figure out how to reach directories outside of the
  master document
Since we failed on the second idea so far, what about the first?
I just want to avoid that doxygen cycles through the entire GRASS
tree and takes forever...
Markus
