[GRASS-dev] erorrs compiling i.pr modules
Dylan Beaudette debeaudette at ucdavis.edu
Mon Aug 3 13:54:28 EDT 2009
On Sunday 02 August 2009, Markus Neteler wrote:
> On Fri, Jul 31, 2009 at 6:40 PM, Dylan Beaudette<debeaudette at ucdavis.edu>
wrote:
> > On Thursday 30 July 2009, Markus Neteler wrote:
> >> On Tue, Jul 28, 2009 at 9:46 PM, Dylan
> > wrote:
> >> > On Tuesday 28 July 2009, Moskovitz, Bob wrote:
> >> >> I ran into this problem before.  I believe the api has changes for a
> >> >> 2 argument Vect_build to a one.  See what happens when you remove the
> >> >> second one.
> >> > That did the trick. Patch is attached.
> >> Thanks, fixed plus another compilation issue.
> >> > It seems like there is no 'install'
> >> > target for these files:
> >> > $> sudo make MODULE_TOPDIR=/home/dylan/src/grass_6/ install
> >> > make: *** No rule to make target `install'.  Stop.
> >> Yes, because it is a set of subdirs and my skills aren't sufficient to
> >> modify the Makefile rules to permit for recursive installation...
> >> You need to walk through the subdirs and run it from there.
> >> Since "make clean" runs recursively, it might be "easy" to apply
> >> this also to "make install" but I would leave this to someone else.
> >> Markus
> > Thanks Markus. Unfortunately I don't know how to to this either...
> I guess I figured it out: done in r38565 in GRASS 6.5.
> To test:
> - update i.pr for a small update
> - update GRASS 6.5 include/Make
> - compile/install GRASS
> - try again with i.pr
> - report here
> Markus
Thanks for looking into this Markus.
I updated GRASS and the addons SVN branch, and now I can install i.pr modules
from the top-level directory. Nice!
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
