[GRASS-dev] Re: [GRASS GIS] #669: let users save/load mapcalc expressions
GRASS GIS trac at osgeo.org
Mon Aug 3 14:12:33 EDT 2009
  Reporter:  timmie       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.5.0
 Component:  wxGUI        |     Version:  svn-develbranch6
Resolution:               |    Keywords:  map calculator
  Platform:  Linux        |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:6 1gray]:
 > This is already possible when using the command-line interface.
 Consider, e. g.:
   bash$ (r=baz ; a=foo ; b=bar ; r.mapcalc "\"$r\" = \"$a\" + \"$b\"")
 Note that r.mapcalc allows map names to be quoted using either single or
 double quotes, so the above can be written as:
   bash$ (r=baz ; a=foo ; b=bar ; r.mapcalc "'$r' = '$a' + '$b'")
 This is probably clearer than using backslash and double-quote.
Ticket URL: <https://trac.osgeo.org/grass/ticket/669#comment:7>
