[GRASS-dev] [GRASS GIS] #717: Vector digitizer tool in wx-Python GUI crashes after changing mapsets.
GRASS GIS trac at osgeo.org
Tue Aug 4 19:41:47 EDT 2009
 Reporter:  voncasec          |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.0
Component:  wxGUI             |     Version:  6.4.0 RCs
 Keywords:  vector digitizer  |    Platform:  Linux
      Cpu:  x86-64            |
 After digitizing vector features in Mapset1 for example, I close the
 digitizing tool, change my mapset to Mapset2 and re-open the digitizing
 tool to digitize new features in my second mapset. However, after
 selecting "New Vector Map" to digitize and giving it a name, I receive the
 following error:
 '''Vector digitizer error.'''
 Unable to open vector map <test at Mapset2> for editing.
 Data are probably corrupted, try to run v.build to rebuild the topology
 (Vector->Develop vector map->Create/rebuild topology).
 running v.build does not repair the newly created (featureless) vector
 layer. The only fix I have found is to exit out of grass and restart using
 the mapset2.
Ticket URL: <http://trac.osgeo.org/grass/ticket/717>
