[GRASS-dev] Re: [GRASS GIS] #671: wxgui: v.distance to_column option inaccessible
GRASS GIS trac at osgeo.org
Thu Aug 6 09:05:24 EDT 2009
  Reporter:  mlennert  |       Owner:  martinl
      Type:  defect    |      Status:  closed
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  6.4.0 RCs
Resolution:  fixed     |    Keywords:  v.distance to_column
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by mlennert):
 Replying to [comment:16 martinl]:
 > Closing this ticket as fixed in trunk and "partly fixed" in
 devbr6/relbr64.
 > Martin
 > PS: Still not sure if to backport the bugfix from trunk to devbr6.
 It seems to work well in grass7, so I would plead for backporting it.
 However, there is one issue: would it be possible to have a select list
 that is also writable ? The problem arises with modules such as
 d.vect.thematic, where you have to select a column on which you wish to
 base your thematic map, but you can also use an expression, i.e.
 col1/col2. In the current form of the column selector, it is impossible to
 write such expressions in the GUI.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/671#comment:17>
