[GRASS-dev] Re: About the vector changes
Mon Aug 10 17:33:46 EDT 2009
Markus Metz wrote:
> Maybe it is less effort and less complicated to make everything LFS-safe
> instead of creating workarounds for modules that are not LFS-safe when
> LFS is enabled for lib/gis? One way or the other, I guess these modules
> need to be identified and possibly modified.
It certainly looks that way.
It's basically a case of examining anything which uses lseek(),
fseek() or ftell(), converting fseek/ftell to G_fseek/G_ftell
respectively, and ensuring that offsets are calculated and stored
using off_t.
I *think* that I fixed all of the lseek() cases some time ago, but I
didn't touch the fseek/ftell cases (we didn't have G_fseek/G_ftell at
that time).
