[GRASS-dev] gmath/gpde Patch for grass6.5 and grass7
Soeren Gebbert soerengebbert at googlemail.com
Thu Aug 13 09:10:05 EDT 2009
Hello Hamish,
2009/8/13 Hamish <hamish_b at yahoo.com>
> Soeren wrote:
> > In case the developers don't have any objections
> > against the patch, i would like to see them commited to the
> > svn repositories.
> > Because i do not have write permissions on the osgeo grass
> > reporitory, a developer with write acces must do this
> > please.
> since you were already accepted as a developer and had CVS write access
> on the old server, all you need to do now to activate SVN write access on
> the new server is post to the grass-psc mailing list giving your osgeo ID
> and that you have read+understand+accept the RFC2 document.
> see
> https://trac.osgeo.org/grass/wiki/HowToContribute#WriteaccesstotheMainGRASS-SVNrepository
thanks for the hint.
I will "activate" my SVN access  right now and will submit the patches in
the near future,
if there are no objections against the changes and the new LGPL'd ccmath
library?
best regards
Soeren
> cheers,
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090813/ff617f64/attachment.html
