[GRASS-dev] New: v.db.droprow
Markus Neteler neteler at osgeo.org
Fri Aug 14 04:43:11 EDT 2009
On Fri, Aug 14, 2009 at 10:15 AM, Martin Landa<landa.martin at gmail.com> wrote:
> 2009/8/11 Markus Neteler <neteler at osgeo.org>:
>> It removes vector objects (point, line, area, face etc.) from a vector
>> map through attribute selection in the table.
> Also not sure if we need this script.
How would you do vector removal based on attributes?
> In any case the name is probably
> misleading. Prefix 'v.db' indicates that the module modifies only
> attribute data, not geometry(?)
Perhaps yes (I considered it a v.db.* since it uses the attribute table).
> I have some questions regarding Bash script:
> * are these extra checks needed (it's done by v.extract) [1,2]
Yes, I think so: if you create a map with v.random it won't have
a connected table, so better don't badly crash. Likewise with
a non-existing map. I used existing msg strings (for translation).
> * unused variables [3]
Removed.
> * G_OPT_OUTPUT instead of G_OPT_INPUT? [4]
Right, fixed.
> Thanks, Martin
> [1] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow#L86
> [2] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow#L92
> [3] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow#L97
> [4] http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow#L116
thanks
Markus
