[GRASS-dev] New: v.db.droprow
Martin Landa landa.martin at gmail.com
Fri Aug 14 06:16:19 EDT 2009
2009/8/14 Martin Landa <landa.martin at gmail.com>:
>>> * are these extra checks needed (it's done by v.extract) [1,2]
>> Yes, I think so: if you create a map with v.random it won't have
>> a connected table, so better don't badly crash. Likewise with
>> a non-existing map. I used existing msg strings (for translation).
BTW, why are you requesting the input vector map from the current mapset?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
