[GRASS-dev] [GRASS GIS] #719: v.edit tool=break: breaking more then 6 coords and producing of an unexpected line
GRASS GIS trac at osgeo.org
Fri Aug 14 10:08:30 EDT 2009
unexpected line
 Reporter:  achim              |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect             |      Status:  new
 Priority:  major              |   Milestone:  6.5.0
Component:  Vector             |     Version:  svn-develbranch6
 Keywords:  v.edit tool=break  |    Platform:  Unspecified
      Cpu:  Unspecified        |
 1/2
 using v.edit tool=break results for more than 6 coordinates in an error:
 "Attempt to delete dead feature".
 after error message the topology of vector-file is destroyed:
 WARNING: Size of 'coor' file differs from value saved in topology file
 WARNING: Please rebuild topology for vector map
 two equal coordinates result in an error, too
 2/2
 breaking a line returns three(!) lines: the two desired and one straight
 connecting the breaking point and the end or start point of the input-line
Ticket URL: <http://trac.osgeo.org/grass/ticket/719>
