[GRASS-dev] Re: [GRASS GIS] #727: Rast_get_d_color() segfault in trunk
GRASS GIS trac at osgeo.org
Fri Aug 21 04:43:42 EDT 2009
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  6.4.0
 Component:  Raster  |     Version:  svn-trunk
Resolution:          |    Keywords:  r.what, Rast_is_null_value()
  Platform:  Linux   |         Cpu:  x86-64
Comment (by glynn):
 Replying to [ticket:727 hamish]:
 > I'm getting a segfault in grass7's r.what if I give it an out-of-region
 coordinate.
 Program received signal SIGSEGV, Segmentation fault.
 (gdb) bt
 #7  0x0000000000402783 in main (argc=5, argv=0x7fff847d8c98) at main.c:384
 The code in question is:
 383                 if (out_type[i] == CELL_TYPE)
 384                     Rast_get_c_color(&cell[i][cache[point].col],
 385                                          &red, &green, &blue,
 &ncolor[i]);
 386                 else
 387                     Rast_get_d_color(&dcell[i][cache[point].col],
 388                                          &red, &green, &blue,
 &ncolor[i]);
 > print cache[point].col
 $3 = -19297
 The above code needs to check that the indices are within the array's
 bounds.
Ticket URL: <https://trac.osgeo.org/grass/ticket/727#comment:4>
