[GRASS-dev] Re: [GRASS-SVN] r38872 - grass/trunk
Martin Landa landa.martin at gmail.com
Wed Aug 26 08:44:57 EDT 2009
2009/8/26  <svn_grass at osgeo.org>:
> Author: glynn
> Date: 2009-08-26 08:41:06 -0400 (Wed, 26 Aug 2009)
> New Revision: 38872
> Modified:
>   grass/trunk/configure
>   grass/trunk/configure.in
> Log:
> Revert r38867 (bogus GEOM check)
can you explain why it's bogus. Now configuration fails with
checking for geos-config... /usr/local/bin/geos-config
checking for geos_c.h... yes
checking for GEOSGeom_createLinearRing in -lgeos... no
configure: error: *** Unable to locate GEOS library.
initGEOS or GEOSGeom_createLinearRing are defined in GEOS C API (geos_c)...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
