[GRASS-dev] Re: [GRASS GIS] #710: v.db.select: allow output to a file
GRASS GIS trac at osgeo.org
Wed Aug 26 14:28:53 EDT 2009
  Reporter:  mlennert     |       Owner:  martinl
      Type:  enhancement  |      Status:  assigned
  Priority:  normal       |   Milestone:  6.5.0
 Component:  Vector       |     Version:  svn-trunk
Resolution:               |    Keywords:  v.db.select file
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:5 mlennert]:
 > Replying to [comment:2 martinl]:
 > > Slightly changed patch applied in trunk, r38606. I have changed
 "output" to "file". If reasonable I will backport it to devbr6.
 > Thanks a lot. Should this also be implemented in db.select ?
 Done in r38876 (and backported to devbr6 in r38877). Can we close the
 ticket now?
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/710#comment:6>
