[GRASS-dev] Re: About the vector changes
Sat Aug 29 12:34:12 EDT 2009
Glynn Clements wrote:
> I suggest:
> 1. Remove OFF_T_TEST.
> 2. Add:
> 	#ifdef HAVE_LONG_LONG_INT
> 	#define LONG_LONG_TEST 0x0102030405060708LL
> 	#endif
> 3. Change the initialisation of u_o to e.g.:
> 	    if (nat_off_t == 8)
> 		u_o = (off_t) LONG_LONG_TEST;
> 	#else
> 		G_fatal_error("Internal error: can't construct an off_t literal");
> 	#endif
> 	    else
> 		u_o = (off_t) LONG_TEST;
Done in r38916.
