[GRASS-dev] Some v.out.ogr shortcomings
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Mon Aug 31 08:55:55 EDT 2009
Dear all,
After my recent experiments with v.out.ogr, I noticed a number
of weaknesses that show particularly when working with data
stored in a DBMS.
I would like to put some work into improving it.
So could I have your comments on the following thoughts,
please?
1. The GRASS primary key "cat" column always gets exported
(and upon re-import and export, you may get "_cat", ...).
This does not always seem to be useful and can even be
significant bloat for very large datasets. How about adding
a flag to drop (or preserve?) it in the output?
2. There is currently no implemented action for exporting
"Kernel" type geometries. Should they be exported simply
as 3D points?
3. Export in general is _very_ slow (I think this has been
discussed here before). On my machine v.out.ogr takes almost
8 mins to export 32,000 points to an SQLite database file.
Compare that to ogr2ogr which does the same job (plus importing
the input data) in 4 seconds! All that extra time seems to
be spent in mk_at() which generates the attribute table.
The DBMS management code look like quite some overhead.
How about loading all the attribute tables into a simple
in-mem C structure in one go and dumping them straight into
each OGR feature definition on export? This would mean that
the whole attribute table needs to be in memory (but it
should also be possible to do this in segments) and could
be controlled via a module flag. Or is that unlikely to
gain much performance?
4. SQLite happens to be an OGR driver that does not supports
overwriting existing datasources. Thus,
  Ogr_ds = OGR_Dr_CreateDataSource(Ogr_driver, dsn_opt->answer,
           papszDSCO);
as used by v.in.ogr will always fail. This means that users
are confined to exporting data to a new table in a new SQLite
database only. In fact, SQLite is capable of updating an existing
database, by adding a new table to it. How about a new flag "-u"
to open an OGR datasource in "update" mode, using OGR_Dr_Open(?)
This could also benefit other OGR drivers with similar design
issues.
Thanks,
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
