[GRASS-dev] Customize menudata.ml
Tue Dec 1 04:16:23 EST 2009
Luis Lisboa wrote:
> I want customize my DW-E menu and add a few new menus bla bla bla. I'm
> editting XML file but I'm having a problem. Special characters such as ñ á à
> etc are not recognized.
> Question: How can I parse this characters in the XML file?
> Note: I have set Spanish language and the GUI supports those characters.
What errors are you getting?
The menudata.xml file is treated as UTF-8; if you use e.g. ISO-8859-1,
you will get a parse error.
Provided that I use UTF-8, non-ASCII characters in menu labels or
description strings seem to work okay (using them in commands might be
a problem).
