[GRASS-dev] Shell scripts
Michael Barton Michael.Barton at asu.edu
Tue Dec 1 10:11:22 EST 2009
Right you are. I hadn't mentioned this because I thought it wasn't
working and didn't have time to look into it. But I only had the wrong
syntax.
The d.* commands don't produce a history in the output console, but
that is easily changed.
A couple of additional modifications would give this more the feel of
the system console.
1) Have the typed input go into the styled text window (output
console) instead of a separate command entry box
2) Have the styled text window bind carriage returns so that it will
treat any line under the cursor as a "command" to parse when return is
pressed.
As Glynn says, this is not exactly the same as a system terminal, but
it comes pretty close in functionality.
Michael
On Dec 1, 2009, at 5:54 AM, Martin Landa wrote:
> Hi,
> 2009/12/1 Michael Barton <Michael.Barton at asu.edu>:
>> On the other hand, if these folks DO want to use the wxPython GUI
>> (and all
>> the interactive tools on the canvas) but simply want to be able to
>> get maps
>> displayed in the canvas by typing commands instead of adding them
>> to the
>> layer manager, then I think the better way to go is to enhance the
>> wxPython
>> console. This solution could be of interest to power users on all
>> platforms.
> It already works, try to type in wxGUI prompt, e.g. `d.rast
> map=elevation.dem`. Anyway I think that something like `d.mon wx0`
> would be usable.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
