[GRASS-dev] Re: [GRASS GIS] #831: v.category options sum, del, and add do nothing
GRASS GIS trac at osgeo.org
Sat Dec 5 11:05:52 EST 2009
  Reporter:  isaacullah   |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  reopened
  Priority:  major        |   Milestone:  7.0.0
 Component:  Vector       |     Version:  svn-develbranch6
Resolution:               |    Keywords:  v.category
  Platform:  All          |         Cpu:  All
Changes (by cmbarton):
  * status:  closed => reopened
  * type:  defect => enhancement
  * version:  6.4.0 RCs => svn-develbranch6
  * resolution:  invalid =>
  * milestone:  6.4.0 => 7.0.0
Comment:
 This is worth keeping open as an enhancement request rather than a defect.
 v.category dates to an era when vectors did not routinely have attribute
 tables, but only cat and label values like rasters.
 For vectors with attribute tables, v.category becomes highly problematic.
 If it alters the cat values without altering the corresponding cat values
 in the associated attribute table, all links between the vector objects
 and their attribute data are irretrievably lost (or lost with out a great
 amount of work to retrieve them).
 My suggestion is to add a flag that will allow v.category to
 simultaneously change the cat value in the vector AND the corresponding
 cat in the linked attribute table of same layer.
 Because this enhancement request is a change in functionality, I've also
 bumped this to milestone 7.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/831#comment:4>
