[GRASS-dev] [GRASS GIS] #832: menu tree in help menu won't run commands
GRASS GIS trac at osgeo.org
Sun Dec 6 13:41:01 EST 2009
 Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.5.0
Component:  wxGUI     |     Version:  svn-develbranch6
 Keywords:            |    Platform:  All
      Cpu:  All       |
 Double clicking a menu tree item in the the help/menu tree will not run as
 written.
 [[BR]]
 [[BR]]
 RunMenuCmd will only accept an event from selecting a menu object. It
 won't run if you pass it a command. Probably a command from this interface
 needs to be run through the command-line interface code rather than the
 menu event handlers. [[BR]][[BR]]
 Also, the static text box needs to be instantiated before its contents are
 defined or it is not accessible to Mac users (I don't know about Windows).
Ticket URL: <http://trac.osgeo.org/grass/ticket/832>
