[GRASS-dev] Re: Shell scripts
Martin Landa landa.martin at gmail.com
Sun Dec 6 15:08:34 EST 2009
2009/12/6 Tim Michelsen <timmichelsen at gmx-topmail.de>:
>> The p.* scripts are semi-functional and should be rewritten to Python.
>> Not having d.mon/d.rast/d.vect/d.zoom commands is for me, Helena, others
>> the obstacle to not use GRASS 7 as primary version.
>> Since the needed (wx)GUI pieces are there, I still hope that someone skilled
>> is rewriting it in Python. For us it is essential to continue with command line
>> in GRASS 7.
> What about adding a IPython-like interactive console?
> IPython has history, tab-completion and is emeddable.
btw, tab-completation for GRASS commands is partly implemented in 6.5+
(see gui/wxpython/gui_modules/prompt.py).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
