[GRASS-dev] Re: GRASS-dev] Re: Shell scripts
Michael Barton michael.barton at asu.edu
Sun Dec 6 16:23:05 EST 2009
 From the testing I've been doing, it looks like we can easily
collapse the command entry functions into the StyledTextCtrl output
window and do away with the separate command entry area. This tab
completion of commands could be run through the STC tootip interface
or possibly the autocomplete interface. I've mostly worked out how to
get a listing of maps to insert using the STC autocompletion interface.
This makes for a simpler, cleaner, and potentially more functional CLI
interface for the GUI. It seems like a good idea to head in that
direction. What do you think?
Michael
On Dec 6, 2009, at 1:08 PM, grass-dev-request at lists.osgeo.org wrote:
> Date: Sun, 6 Dec 2009 21:08:34 +0100
> From: Martin Landa <landa.martin at gmail.com>
> Subject: Re: [GRASS-dev] Re: Shell scripts
> To: Tim Michelsen <timmichelsen at gmx-topmail.de>
> Cc: grass-dev at lists.osgeo.org
> Message-ID:
>        <f8fe65c40912061208w25121f96l4f663e6a8b18aea8 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> 2009/12/6 Tim Michelsen <timmichelsen at gmx-topmail.de>:
>>> The p.* scripts are semi-functional and should be rewritten to
>>> Python.
>>> Not having d.mon/d.rast/d.vect/d.zoom commands is for me, Helena,
>>> others
>>> the obstacle to not use GRASS 7 as primary version.
>>> Since the needed (wx)GUI pieces are there, I still hope that
>>> someone skilled
>>> is rewriting it in Python. For us it is essential to continue with
>>> command line
>>> in GRASS 7.
>> What about adding a IPython-like interactive console?
>> IPython has history, tab-completion and is emeddable.
> btw, tab-completation for GRASS commands is partly implemented in 6.5+
> (see gui/wxpython/gui_modules/prompt.py).
> Martin
