[GRASS-dev] Re: [GRASS GIS] #807: r.watershed doesnt consider longer distance to diagonal neighbouring pixels
GRASS GIS trac at osgeo.org
Sun Dec 6 23:27:08 EST 2009
  Reporter:  aread   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Raster  |     Version:  6.4.0 RCs
Resolution:          |    Keywords:  r.watershed
  Platform:  All     |         Cpu:  All
Comment (by helena):
 I finally had chance to look at it and it does make a significant
 difference (much more than I would have ever guessed)
 and I think that after some more testing
 the fix should go to the GRASS64 release as a bugfix.
 Some examples from the nc_spm_08 data set
 1m resolution
 old
 http://skagit.meas.ncsu.edu/~helena/wrriwork/lakewh/flowD8dem.jpg
 new
 http://skagit.meas.ncsu.edu/~helena/grasswork/accum_5Kdiagfix.png
 red is the stream from high res ortho
 http://skagit.meas.ncsu.edu/~helena/grasswork/accum_5Kdiagfix2.png.png
 I haven't done any serious testing but brief visual comparison indicates
 that the fix may improve the accuracy of stream extraction beyond
 just looking more realistic)
 red-sreams from ortho, blue-old, black-new
 http://skagit.meas.ncsu.edu/~helena/grasswork/accum_diagfix_streams.png
 example with the 30m ned shows quite a few differences -
 see the first stream from the west on these two images with the fix
 apparently better although still with some error:
 http://skagit.meas.ncsu.edu/~helena/grasswork/accum_10Korig.png
 http://skagit.meas.ncsu.edu/~helena/grasswork/accum_10kfix.png
 It would be very useful if anybody who has some other data than nc_spm and
 some orthos to compare the results with runs another test and confirms
 that
 the change can go into 64, Markus, thanks for fixing it so quickly,
 Helena
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:3>
