[GRASS-dev] Re: [GRASS GIS] #807: r.watershed doesnt consider longer distance to diagonal neighbouring pixels
GRASS GIS trac at osgeo.org
Mon Dec 7 10:03:38 EST 2009
  Reporter:  aread   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Raster  |     Version:  6.4.0 RCs
Resolution:          |    Keywords:  r.watershed
  Platform:  All     |         Cpu:  All
Comment (by mmetz):
 Replying to [comment:2 hamish]:
 > how does the patch (or r.watershed for that matter) work with lat/lon
 locations?
 Tested only in real projections, should most probably use geodesic
 distance for lat/lon locations?
 I'm busy investigating the new patch for its behaviour in depressions,
 just to make sure I do not introduce another bug. Outside depressions it
 looks ok, flow directions are set as expected.
 > maybe that had something to do with the removal (????)
 > FWIW svn (cvs) history back to 1999 (~r1 to r3) can be found in the
 grass54 branch even if the history has been broken in trunk. Also the old
 ViewCVS is AFAIK still up & running (link on trac wiki page).
 The change happened between 1990 (grass32) and 1998 (grass40), I did not
 manage to find that commit :-(
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:4>
