[GRASS-dev] Error while compiling i.pr Windows GRASS6.4
Mon Dec 7 10:56:43 EST 2009
António Rocha wrote:
> Just one question: during compilation i got these errors: ERROR:
> G_getenv(): Variable LOCATION_NAME not set
> Is this associated with manual html page that is created with the
> compilation?
Yes.
The process for generating HTML pages involves running the module with
the --html-description flag. Running any GRASS module requires a
minimal GRASS "session" to be established, which essentially means
that $GISRC must point to a file containing settings for the GISDBASE,
LOCATION_NAME and MAPSET variables
In the case where the module is being run with the --html-description
flag (or --help, etc), the actual value don't matter, but the
variables must be set.
Running make with e.g.:
	GISRC=$HOME/.grassrc6 make ...
should suffice.
In GRASS 7.0, the demolocation directory (which is used to provide a
minimal GRASS session for the normal build process) is installed, so
the rules to build HTML files should work even when building add-on
modules, but this isn't the case for 6.x.
[Actually, most of the problems relating to building add-ons should be
fixed in 7.0, but the existing add-ons are written for 6.x.]
