[GRASS-dev] Re: a better console and better diff
Michael Barton michael.barton at asu.edu
Fri Dec 11 17:16:24 EST 2009
For those that ask, here is a set of screenshots showing using the
proposed terminal to enter a simple grass command. Hard to capture the
actual action, but perhaps this series 1-4 conveys it.
http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console1.jpg
http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console2.jpg
http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console3.jpg
http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console4.jpg
Michael
On Dec 10, 2009, at 6:54 PM, Michael Barton wrote:
> A quick note. I forgot to mention that there is also command history
> as before. Press ctrl-up or ctrl-down.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Dec 10, 2009, at 5:51 PM, Michael Barton wrote:
>> First, thanks to all who advised me on making a diff that actually
>> patches correctly (I hope).
>> Here is a console with full autocomplete and calltips. For GRASS 6.5
>> I've put it on auto to show how it can work, but the autocompletion
>> could move to control key combinations too.
>> --Type a grass command. When you get to the ".", it brings up an
>> autocomplete list of relevant commands. Keep typing (or mouse up/
>> down)
>> until you find the one you want and hit return.
>> --Press <tab> to see full calltips of command syntax for each command
>> entered (one command per line please)
>> --As you type the command arguments, hitting "=" and "," following an
>> "=[string]" combination will bring up context-sensitive lists of
>> relevant maps or other data sets (e.g. regions where appropriate).
>> --You can type ctrl-space to bring up a context sensitive list of
>> maps
>> for raster, vector, etc. at any place in the command.
>> --Pressing return on the command line will run it.
>> This will accept shell commands (redirects and pipes don't work but
>> could), grass commands without arguments (brings up the GUI dialogs),
>> and grass commands with the short form arguments (r.info mymap) as
>> well as full grass commands with argument=value format.
>> ****IMPORTANT WARNING***** Turn OFF the preferences/configuration for
>> default raster color tables. This is causing a bug to affect any
>> command entered from this console or the existing command prompt.
>> console_example4
>> .patch><ATT00001.txt><goutput.py><wxgui.py><ATT00002.txt>
