[GRASS-dev] Re: r39983 and r39984 - Module dialogs now size correctly on opening.
Michael Barton Michael.Barton at asu.edu
Sun Dec 13 15:11:37 EST 2009
Markus,
Then we need to work together on this.
Before, I made this change, modules would often open on my screen with
all the controls piled in the upper left and the description
unreadable. In my case (and probably yours too), a slight resize
corrects it. But we don't want anyone to have to do that. I'll try
some other fixes and can either commit them or send them to you. What
is your preference?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 13, 2009, at 12:19 PM, Markus Metz wrote:
> Err, module dialogs no longer size correctly on opening (Linux
> Fedora 10 and Fedora 12), was just fine before r39983 and r39984,
> now the lower part is not visible, missing are the essential buttons
> close, apply, ok, help for the d.* modules and close, run, copy,
> help for other modules, amongst other options, depending on the
> module. Could you please revert these changes? Also please be aware
> of modules with lots of options and a system with low screen
> resolution, the adjusted dialog height may exceed the screen height,
> something highly annoying (running some virtual machines here for
> testing where that would be a problem).
> Thanks,
> Markus M
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20091213/49438bac/attachment.html
