[GRASS-dev] Re: [GRASS GIS] #807: r.watershed doesnt consider longer distance to diagonal neighbouring pixels
GRASS GIS trac at osgeo.org
Wed Dec 16 02:58:23 EST 2009
  Reporter:  aread   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Raster  |     Version:  6.4.0 RCs
Resolution:          |    Keywords:  r.watershed
  Platform:  All     |         Cpu:  All
Comment (by hamish):
 Replying to [comment:7 mmetz]:
 > MFD is not affected, i.e. this fix would be mostly needed
 > by 64 because it doesn't have MFD. OTOH, these are drastically
 > different results and before submitting to 64 I would like to do
 > more testing to 1) make sure I have properly understood and
 > implemented Chuck Ehlschlaeger's description and 2) figure out
 > why the correction present in grass32 was removed for grass4,
 > there must have been a reason (maybe because the code did not
 > exactly match the description and caused problems in special
 > cases).
 maybe a silly question, but have you tried emailing Chuck to ask? He is
 still contactable AFAIK & has been quite responsive to questions in the
 past. I'm not even sure if he knows about all the wonderful updates you've
 done and what r.watershed is now capable of.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/807#comment:8>
