[GRASS-dev] Re: a better console and better diff
Martin Landa landa.martin at gmail.com
Wed Dec 16 15:25:09 EST 2009
2009/12/16 Tim Michelsen <timmichelsen at gmx-topmail.de>:
>>> I personally don't mind separate input and output windows.
> -1
> I would like to see:
> 1 Tab for the layer manager, 2dn tab for the command window.
> Maybe there could be the option to optionally redirect the output into a
> text file in
> /tmp/grass.log?
>> I think that separate windows make more sense, but it's worth allowing
>> the input window to be a multi-line field with line-wrap and vertical
>> scrolling, rather than a single-line field with horizontal scrolling.
>> The latter can be annoying when entering long commands.
> +1
wxGUI should support also MDI [1]. More then two windows in SDI could
be too many...
+1 add support for MDI
+1 keep two windows (Map Display and Layer Manager) in SDI (sure you
can open more Map Displays)
+1 keep separated command prompt and log area as different widgets
Martin
[1] http://grass.osgeo.org/wiki/WxGUI#General_GUI_Design
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
