[GRASS-dev] Re: a better console and better diff
Martin Landa landa.martin at gmail.com
Thu Dec 17 02:21:57 EST 2009
2009/12/17 Glynn Clements <glynn at gclements.plus.com>:
> Martin Landa wrote:
>> >> I think that separate windows make more sense, but it's worth allowing
>> >> the input window to be a multi-line field with line-wrap and vertical
>> sorry do you mean separate windows or widgets (in the sense of SDI)?
> Widgets. I.e. typing into a different area of the GUI to where the
> output appears. There isn't much reason for them to use the same
> widget. Terminal emulators have to emulate terminals (which are used
> for e.g. curses applications as well as shells), but there's no reason
> for a dedicated GUI command-line to behave that way.
I agree.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
