[GRASS-dev] New DWG import module
Thu Dec 17 17:02:23 EST 2009
Rodrigo Rodrigues da Silva wrote:
> Hi! I am working on a replacement for v.in.dwg, since it depends on a
> proprietary library. I am using LibreDWG, a recent free software library
> that implements the OpenDWG spec. The module, v.in.redwg, is partially
> implemented, but I haven't figured out how to invoke it from GUI or CLI. I'd
> appreciate if anyone could help me with some information about this.
First, get to to work from the command-line. This should just be a
matter of installing the executable to $GISBASE/bin.
