[GRASS-dev] v.krige in trunk/devbr6
Hamish hamish_b at yahoo.com
Sat Dec 19 22:03:34 EST 2009
Martin wrote:
> I moved v.krige [1] module which has been designed by Anne
> Ghisla (Google SoC 2009) to trunk (r40045) and devbr6 (r40048).
> Please test
trunk$ make distclean; svn up; ./configure ... ; make
[error in v.kridge]
trunk/scripts/v.krige$ make
  File "/usr/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu/scripts/v.krige", line 116, in <module>
    import gselect
  File "/usr/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/gselect.py", line 38, in <module>
    from preferences import globalSettings as UserSettings
  File "/usr/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/preferences.py", line 823, in <module>
    globalSettings = Settings()
  File "/usr/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/preferences.py", line 122, in __init__
    'projFile' : utils.PathJoin(os.environ["GRASS_PROJSHARE"], 'epsg'),
  File "/usr/lib/python2.5/UserDict.py", line 22, in __getitem__
    raise KeyError(key)
KeyError: 'GRASS_PROJSHARE'
make: *** [v.krige.tmp.html] Error 1
rm v.krige.tmp.html
none of the runtime R reqs (cran or R-python hooks) are installed; this
is on debian/lenny amd64.
fwiw,
using "make -j 2" on grass7 I also had build errors on r.terraflow and
iirc the wxNvix/vDigit .cpp modules, both of which resolved themselves
after running make again. this was on a quad core doing heavy work on
a separate sata drive & the other 2 cores. Usually I make 6.5svn with
"-j 8"; never had a problem there.
Hamish
