[GRASS-dev] Re: [GRASS GIS] #827: standalone-installer: execution failed on g.proj.exe -p
GRASS GIS trac at osgeo.org
Mon Dec 21 07:14:09 EST 2009
  Reporter:  timmie        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 Replying to [comment:5 kmithoefer]:
 > I start C:\GRASS\grass64.bat -wxpython and choose the spearfish
 > database and start GRASS. Then I get the message Execution
 > failed g.proj.exe -p .
 does it work using the old tcltk GUI?
 can you run 'g.proj -p' from the GRASS+MSys command line prompt?
 > There is python 2.4 and 2.5 installed.
 anyone else see this problem? if so, do you also have multiple pythons
 installed? which ones? (be as precise as possible please)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/827#comment:7>
