[GRASS-dev] Re: [GRASS GIS] #841: python script modules should use pythonw on OSX; they also ignore GRASS_PYTHON
GRASS GIS trac at osgeo.org
Mon Dec 21 12:47:22 EST 2009
GRASS_PYTHON
  Reporter:  kyngchaos    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  6.5.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by kyngchaos):
 The pythonw requirement is a wxpython thing.  At least they still say to
 use pythonw.
 If you try to run a wxpython-based script from /usr/bin/env python (or
 pythonw), it will run 64bit by default on 10.6, which won't work because
 wxpython is not possible 64bit (yet).
 The problem with the automatic pythonw is that the reexec didn't work and
 the GUI would never start on 10.6, and it even affected some non-OSX
 systems for some reason, so I removed the reexec and required pythonw to
 be used explicitly (r39207).
Ticket URL: <https://trac.osgeo.org/grass/ticket/841#comment:4>
