[GRASS-dev] Re: Wingrass-Installer + Win7
Massimo Di Stefano massimodisasha at gmail.com
Mon Dec 21 13:10:16 EST 2009
hi All.
thanks for the hard work!
I tried the installer on a windows 7 virtual box machine,
it install fine without errors, also the automatic sperfish download works fine.
i tried just to load some files,
nviz works with tcltk (no in python) while vdigit don't works.
i had not to much time to test it, but if you point me to a script to beused as "unit test" maybe based on spearfish, i'll be appy to try it.
let me know if you need to test a precise instruction.
regards,
Massimo.
Il giorno 21/dic/2009, alle ore 13.18, Hamish ha scritto:
>>> Modified: grass-web/trunk/grass64/binary/mswindows/index.html
>>> +<li><I> For Windows XP and Vista, 32 and 64 bit</I> <!-- how about Win7?-->
>> the  NSIS used for packaging the self-installer should
>> be Win7-aware, but I have no Win7-box for testing the
>> installer.
> ok. we will wait for a report of a positive experience before claiming that
> we support it.
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
